As most know I'm hard on my trans...
It currently will creep up over 200 on a long drive even seen 230 in the hills. Trying to make it last and want to try and get it under 200 for the hills. My current setup is just this trans cooler in front of the radiator. https://www.summitracing.com/parts/...19QIVYB6tBh09UgzmEAAYASAAEgIunPD_BwE#overview
I know on paper it should be ran through the radiator then through the cooler, but will this be the fix or adding a 2nd or bigger cooler be the answer?
