I know people have their preferences when it comes to gaskets. Seeking some different opinions from this group.
I have a TH350 that leaks horribly it has the standard black neoprene/rubber gasket torqued down. It leaks pretty bad. I did not install this.
In the past I have used this type of gasket with a nicr smearing of Gasgacinch and experienced no leaks.
Anyway, what gaskets do you guys run or if you recommend something other than the standard Bkack rubber gasket.
A friend gifted me this nice and purty pan any thoughts on usuing it? I do like the drain plug feature but have read the bolt can come in contact with the filter.
