Orangatangin
- Joined
- Dec 10, 2000
- Posts
- 5
- Reaction score
- 0
I need some desperated help. I just put in my new transmission (700r4) and got everything hooked up. My problem is that my tranny won't even go into gear. I have the linkage hooked up and it turns into the tranny but nothging engages. I have the fluid level checked perfectly. There are two wire connections that aren't hooked up because thay are broken. One goes into the tranny and the other to the transfercase. Would this prevent the transmission from going into gear? Thanks for the help.
