What is the difference between transmission lines for 2wd and 4wd. Mine are in bad shape and I would like to change them out. Heading to the junkyard today but they normally have very few 4wds, but plenty of 2wds.
5/16 reg old brake fuel lines if you cant find any good ones.
and dont forget 1/2 and 9/16 line wrenches. and if you got them stubby regular wrenches for more swing in the tight place. and mabye mini cresent wrench to hold the brass fitting in tranny case from spinnin if thay are tight.
