elyon
So my rebuilt TH400 failed. I think it was due to blocked cooler lines. The torque converter was pushing forward into the dust cover under load and in the process ate my thrust bearing and crank. Pulled the engine to replace the crank and found oil in #5 cylinder. Pulled the head and found a blown head gasket, worn ring lands on top, lose valve guides, exhaust valves hammering the seats. Instead of a new 350 crate engine, I elected to have my engine rebuilt as a 383. Supercharger going back on making about 5 lbs. of boost. Lunati supercharger cam going in to compliment. 8.7:1 compression ratio, Hedmann full length headers, water methanol injection.
Can you say "excited."
This thing should make some decent torque.
Also have a new Tactical Armor Group multi carrier sitting on a pallet to be mounted. Only took 9 months to get it!!! They build a nice bumper, but will string you along forever in the build process. They live up to their reputation unfortunately.
