Hi all,
Now that I've handled the brake leak, my next maintenance job is changing my transmission fluid and filter. Then I'm going to coat my undercarriage for winter.
Transmission Question:
My pan doesn't have a drain plug. I looked through a bunch of old threads on the forum and found some folks talking about the B&M drain plug kit (https://www.amazon.com/80250-Automatic-Transmission-Universal-Drain/dp/B00029WR78). That is going to be my plan unless you all think it is a bad choice? How many of you guys run larger aftermarket pans that came with a drain plug?
Undercarriage Question:
I plan on painting a bunch of stuff underneath with old motor oil to protect it from snow / general winter BS. Aside from the frame and axles, what should I make sure to cover? Also, should I wash under there before I paint, or leave the dirt on there?
Thanks for any and all input, I really appreciate it.
Drew
Drew
. I might have to put myself through the nightmare at least once to see whether it is worth it. The advantages are nice though e.g. better cooling.
