rampage
3/4 ton status
Improvise! How about a piece of a wire coat hanger with a small bend at the end. Could even use that hammer to flatten the end of it if you need to.
Under coat it with motor oil?
First question would be why oil? Its not going to stay it will wash off first rain storm. Oilly things dont make it easy to work on. How will you tell when it is leaking where it is leaking from ?
Paint and keep it clean then paint it again when the paint wear off.
So far, my only tools to get that o-ring out are a hammer, a small (micro) flathead, and needle nose pliers. I'm not getting very far...
