trukker
I let my blazer set for about a week, this evening when I cranked it up tranny fluid came out of the fill tube while at high idle . This has happened twice, Dip stick says it is not over full.The only thing that i have changed is front seal(when i swapped in my 383).
It dosent do it when I run it on a regular basis. after it does this I can kill it and restart and everything is fine What would be causing this? filter or????
btw it is stock 84 700r4 tranny
