Today, I had to drive 45 min for a stupid VA appt. I drove 67 to 70 mph, no AC, ambient temp 95 to 100. I turned the transmission cooler fan on once it hit 180.
Transmission temp at the pan was 220 according to the gauge, engine oil temp was 160 on the gauge, coolant at the bottom of the radiator was 150 on the gauge.
Coming back, temps climbed a bit, ambient was a solid 100 maybe 105. Trans was reading 240, engine oil temp was 170, coolant temp was 150.
The 240 was kinda scaring me, so I grabbed the laser gun as soon as I stopped and took as many readings as I could, as best I could.
Engine oil temp at the cooler was 204 in and 145 out. 145 reading was erratic.
Transmission oil at the cooler was 160 at the cooler and at the pan was 180 at the bottom of the pan and 201 at the top.
Coolant temp at the thermostat housing was 190.
This was the hottest day that I had driven the Jimmy on the freeway. Jimmy is a SBC 400, 415hp ish, 3.73 gears, 35's, TH350, NP203 with a mile marker part time kit. Rear end has an Eaton G80. I also had the hubs locked during this trip since I have had problems with the hubs not being locked before and trying to engage 4wd after a week or two of not locking the hubs. I have a 1200 stall on the trans and I do believe I have lost 2nd gear. Transmission pan is +3 qt.
So my question/concerns are the transmission temps. Are they okay, or should I plan on replacing the transmission oil every year, just to prolong the transmission life. I need to check the transmission oil cooler lines to see what they have in close proximity of.
Thanks in advance for any help. 240 scared me a bit.
Joel
norcal
Joel
norcal
