Mikey von
I got my trailer wiring mostly figured out and hooked up to the travel trailer and up the mountain. My trailer is about 6500 lbs as it sits now.
Here is my test mountain. Climbing almost 1500' over a few miles. My buddy pulls it at 40 with his 800+ HP log truck loaded. My wife's half ton 2005 Suburban with HD tow package (3.73 gears and trans cooler) pulls it with our trailer in 2nd at around 38-42 mph.
My Suburban pulled it at 42 mph or so in 3rd. I could spin it faster but when I got on it my boost pegged the gauge out at 15 lbs so I did not push it. Temps were great EGT's between 700-900 depending on how hard I pushed. Just holding 40-42 mph, boost was 11-12 lbs. Water temp held steady at 205, didn't budge. I could get some haze/smoke when I got on it but not much.
4th gear was not happening. It would rapidily lose speed and just billow black smoke. EGTs rose a bit, but I never stayed long enough to find out. RPMs would not climb.
My goal is to pull this grade at 55 mph. I know I am under geared with 4.10s and 35" tires. I want either 4.56 or 4.88, not sure. Then look at bigger turbos and better intake? ATA? I am pipe dreaming?
