Mike D
When I first bought my 81 Chev K20 the transfer case shifter rattled like crazy. I decided to remove the NP205 for a closer inspection. As I started to remove the bolts from the crossover I noticed that the transfer case bearing housing was about 1/2 inch further back (out of the case ) . This would allow the front output shaft to move frount to rear excessively, thus allowing the side of the teeth of one gear to rub against the side of the teeth of another. The shift fork was carrying this noise to the passenger compartment. Long story short, I tapped the bearing housing back flush with the case and the rattle went away. As you look at the rear of the NP205 ( opposite the front output shaft ) it is about a 2 - 3 inch diameter case at the center of the housing ( for the front output ) Just be carefull tapping it in because it contains a bunch of needle bearings. Good luck.
