Well I finally got around to installing a Truck Avenger 670 carburetor in lieu of my modified 780CFM Holley 3310-1 after coming to the conclusion that the latter was too large for my 402BBC intended usage. I'm happy to report the difference in throttle response is astounding on the primary side even though the 3310 pump was tuned. The AFR checks out well on my wide-band rig and is more stable to boot. The TA is in stock calibration other than a blue pump cam. The shooter size does not appear to need any changes just yet. Secondary actuation was a bit late with the plain spring so I'm trying the purple spring next.
