FlatBlackBurb
okay here's what i've got. 1987 suburban with a 5.7 TBI motor.
i got an exhaust violation (open after y pipe), and after welding up muffler and cat (that i believe to be clogged) i was driving it and it was fine. but then i took it about 2 miles to the local CHP station so he could write it off. successful. on the way back, my engine started to hesitate a little bit. i thought it was just because of the stupid cat but just to be safe (because my gas gauge is broken) i flipped a U and got 25 bucks of gas. headed home truck hesitated pretty bad and then died. i started it and tried to drive but it acted like it was flodded. no throttle response barely.
so i pulled over in a parking lot and my friend thought it could be the MAP sensor. a quick trip to autozone and a couple minutes later we figured out it wasnt the MAP sensor. it's getting fuel just fine. what could be the problem here? any other sensors on this TBI bulls***? it started and idles fine for a half second and then immediately dies. i got it to drive in reverse for about 20 feet and now it wont drive anymore it dies immediately.
took the air filter off and ran it same thing happened and both injectors were spraying fuel just fine. disconnected fuel lines after the fuel pump and fuel is coming out at a fine rate. when i start it and push the throttle down half way it sputters and acts like it wants to die and when i let up it idles at a higher rate just fine and then dies. i know it can idle fine so i dont think its a spark plug problem. any suggestions???? my trucks stranded in a parking lot in town. it sucks.
The oil pressure switch allows the fuel pump to continue running if there is at least 5 psi of oil pressure and the fuel pump relay fails. It
