Thunder
3/4 ton status
The coil is a good idea too. I was thinking the problem sounded more ignition related rather than fuel.
it may not be recommended but a squirt or two of starting fluid sometimes help you do diagnostics.. namely, if its ignition related or not. (spark, etc)
ugh. i hate fuel pump bs! but you guys are probably right.
before i fully dive into this and replace my pump once AGAIN.... where is the fuel pump relay again? isnt there a way to have the fuel pump run constantly on manual mode? i'd like to see if i could run my truck that way.
either way the fuel pump is most likely being replaced tomorrow. hopefully it comes with the whole assembly because the fuel level floater broke off some time ago and is floating around in my tank somewhere![]()
If you are just getting a code 12 and no other codes try replaceing the distributor module before you do anything else.
