desertrat67swife
Registered Member
So most of you know my other-half and the headache he left me with! If not we have a 1990 burb 6.2L Diesel. I desperately need help fixing the ignition just well enough to get it to pass a state inspection so I can register it so it can sit in the driveway while Ryan is in Iraq!!
I will tell you that I have a beginner level understanding of mechanics. I do pretty well with a Chilton or Hayes.
The truck does not shut off when you turn the key. All the electronics chut off but the damn diesel just keeps on chuggin!!
I know before Ryan left he switched the ignition switch and the key cylinder.. so I have no idea where to go from here.
HELP PLEASE!!!
::::::::::::::::::::::UPDATE (Aug 22, 2008)::::::::::::::::
The truck now shuts off most of the time.
So I think I've narrowed the problem down to the steering column area..
The truck shut off if while turning the key to the off position I push in on the key.. Where do I go from here? Ryan put in a new ignition switch. Is there something that has to be adjusted? ANY HELP IS APPRECIATED!
HELP PLEASE!!!
Did I say that, or did someone else?
when I get home bitch.
