01maroonz71
well, i can't get any power(via test light) to the ignition wire on the starter...the one by it self. everything else has power even at the firewall. everything works, power everything,lights radio..... it did this once before but the next day it started. could it be the neutral safetly switch??? or possibly the starter switch on the column???? is there a way to test these??? the starte will work when jumping it...so it's no the starter or selenoid. like i said, the wire that tells the starter to engage isn't getting power at all. and it looks fine(pulled it off) any ideas???
