K5dreamer
Hey guys and gals, Went out to make a gasoline run for the lawnmower, and the truck wouldnt start.
Symptoms - yellow "wait" light does not turn off. truck cranks with plenty of speed and force, after cranking for a little while, white smoke starts coming out of the tailpipes, not really thick, just enough to blow smoke rings and linger for a bit. it did this a few days ago, but it did start up. Ive had some issues with the "wait" light in the past, but nothing that effected the way the truck ran.
Weather - it is a bit cooler out, and kinda rainy, so without glowplugs it may not want to start. but its hardley cold outside.
Thoughts?
Ive already replaced the glowplugs a couple of years ago (maybe 2), and the wiring harness is in good shape, could it be the glowplug controler? its on the firewall behind the vacuum pump right? how do i test this to make sure its ok, or verify that its failed?
Thoughts?
, is a really angry smiley... trying to think where one might use it.
