Trying to put stuff back together
Domsanti05
Redding ca
Hey guys im trying to get stuff together and don't have the money for a shop and I want to do it on my own but im al.ost done besides this one connection I cant figure out for the life of me what it is or where it goes if someone could name it or give me a lead id be ever so grateful its a 454 and runs great but every time I pop the hood it irks me not seeing it put together thanks guys also I cant post pictures so I put the photos in a Google document ill leave the link right here https://docs.google.com/document/d/13TAsKws8Kp8XtOjOPhMtITLL7srhVPrgdiYJD4Y4ZvU/edit?usp=drivesdk
$25 bucks to support the site and you could post all the pics.
I would but considering that this truck is my daily that 25 goes to gas
That pipe with the two bolt flange?
I am going to venture a guess that it's connected to the A.I.R.
Pump above it, just under the alternator.
It's air injection to get more air to burn off unburnt fuel.
An emissions system in early years
So you have the 86 crew cab right?
Does redding have smog testing or not?
If you do, that's a needed part
I moved out to santa paula so im pretty sure im screwed no matter what cause I did a tru dual cat delete when I had it in redding cause I had a buddy hot smog it for me but im gonna try and find another place out here
I have some air injection parts that came on a 87ish big block.
The part you need is called the a i r diverter valve.
edit actually one of the parts you need is the a i r diverter valve, there are many more parts missing. Looks like headers have been installed that probably what happened to the AIR system.
Yeah now that you mentioned, there are no air tubes on the exhaust manifold.
I just realized I should check my 454 sitting in the shed, it might have the parts you need, I don't need them because it's going in an older truck with newer fuel injection system.
I will let you know
I will let you know
Thanks man I appreciate it
