GNEEnterprises
Registered Member
The carb is the big problem, the tranny would not upshift, the front upper shackle bushings are gone, and the rear shocks got damaged from hitting frame. The missing shackle bushing made it sound like metal on metal bottoming out on every bump on the last lap. I took it easy as I was not sure wtf was broke.
I will go for the 63" front springs now and use a upper shackle pivot point below the frame rail with shorter shackles. I will run 2 leafs so the ride height will be about what it is now, but the axle should droop enough to get me the 15" travel I have been designing around. The 52" springs just cant do that. I know coils are the answer to all this but I am trying to push the limit on what leaf springs can do (and stay close to the SCORE class 3 rules)
I may spend more time organizing races than actually fixing the truck. Ya up for another race..?
