I have the dark spring installed with
15" vac at idle as per cliffs recommendation. He also states that with as much vac you have @ 21 any of the springs would work. The varying cut in rates keep the power system closed at Lower vac levels at idle due to larger cams.
At steady speed/rpm power system should be closed and not in play.
That's where the APT comes in to play to provide proper cruise fuel and also effects off idle performance as you have seen recently.
Remember you are dealing with a heavy truck even tho it's a 4 spd I believe your coming in to soon with the mechanical advance , 10 deg initial should be plenty IMHO.
I would assume the brown spring that was discontinued due to not being needing 11.5 cut in after substantial testing.
