Vacuum keeps the piston (and thus primary rods) pulled into the primary jets right? Won't any air bleeds affect that? How about changing the primary rods to a thinner tip profile?
Bullseye, the richened idle smell was what got me to dial it back and look for another solution that was on the airside and not fuel side.
The QJet I have is OEM for a 160HP '77 automatic and the air bleeds are drilled to size by the factory. It is no longer bolted to a 160HP engine and automatic trans - it has to be somehow not quite right though close enough for sure.I need to reread Cliffs book but at some point tuning the QJet gets into drilling and adding adjustable orifices to reduce the idle air (increases vacuum). Before I do anything, I'd like to find someone that has had a similar tune issue with the QJet and solved it.
My father-in-law thinks it is timing but it does not sound like anyone here has had a lean buck due to timing. This evening if I go for a drive I will try disconnecting the vacuum advance and take the few no stop right turns around the house.
One concern I have is my idle screws are almost seated - I have maybe 3/4 turn of adjustment left. Anything I do to increase fuel through changing rods or reducing air bleeds will probably mean less fuel from the idle circuit and I don't have much room to adjust idle circuit fuel.
I am hoping this is timing related since I have more room to tune there.
