DEMON44
Low-Tech Redneck
I love this stuff......In my oppinion this was an exceptionally good turbo explosion! So this '96 freightliner FLT120 dump truck comes in on a hook........series 60. pre-egr. Check turbo. ok. That is the centre section that is hollow, I picked the turbine wheel out of the y-pipe at the back of the cab. it filleted the down tube, went through the muffler, cleared 3' of flex tube and stopped in the y-pipe. Had to drop the oil pan to pull most of those chunks of housing out of the inside of the block and bottom of the pan. The wheel actually "candy stripped" the down pipe. and cut through in a couple spots.........
and yes the compressor wheel did not grenade and still turns........
