Seems just as simple as my 82 then, now to track down the parts.not much different to change switch. lock plate to deal with and wire fishing. Take the middle lower dash panel out, there should be a long narrow cover over the wires slips into some tabs on the column remove that, to easier pull old/new wires.
You can slip the connector plug through the slot on the column bowl, or you can depin the connector and tape up the terminals to slip through. Sometimes it much easier this way, cut the old switch of the loom, depin new connector tape to old wires, pull old wires from bottom. Be to snap a pic of connector or keep old wires handy to re install pins.
turn signal stalk just pulls out.
I wouldn't call it as simple as the '82, but not a big deal.Seems just as simple as my 82 then, now to track down the parts.
It seems like it's worn out, it doesn't always make the electrical contacts. You are right though, I just don't want to put it back together then take it back apart to move it.I wouldn't call it as simple as the '82, but not a big deal.
There is a small bolt on lever that extends from the switch to the slot on the lever.
I would pull the steering wheel and lock plate before ordering anything, just to confirm that the switch half is cracked. Just in case you need more than that.
I also have pulled the sideways, or outer centering springs off of the switch to lighten the force required to operate it. This still leaves the springs which hold the two halfs of the switch together, making the terminals connect inside the slider part of the switch.
