pennsylvaniaboy
my dad was wondering and i dont kno the answer, but why do you have to grind the shift rails to shift independently
from what i understand, you can use the twin sticks w/o grinding the rod, but you only gain the ability of 2w lo....if you grind the rods, you have the ability to have just the frontend engaged, while the rear isn't pulling, and be able to do front digs
i think i'm going dual sticks just for the 2w lo and the cool factor of 2 transfer shifters, i play in the mud and really don't see an advantage of being able to have just my frontend pulling. will someone please explain better and give an example where just the front pulling would be useful?
From what i understand if you're locked front and rear and get into a situation where you can't turn easily you can put the rear in neutral and keep the front in gear and pull yourself around the turn alot easier.
As for being in the mud, twinstick would only help if you blew up the rear end. Throw it in fwd and limp out, rather than crawling under and unbolting the d-shaft, then driving out in 4wd. Or maybe doing front wheel drive donutsi play in the mud and really don't see an advantage of being able to have just my frontend pulling. will someone please explain better and give an example where just the front pulling would be useful?
. Broken axle shaft blown up rear diff? Limp out in front wheel drive.
If you had it in 4WD you could drive out without a twin stick.
Twin stick primarily gives you the advantage of front drive only (i.e. front digs) and 2 lo. Its not a mud thing.
You could if it was an axle.
Twin stick or not, if the rear driveline is removed/broken the front will drive the same whether its in 4WD or FWD.
If a mud hole is bad enough to break a shaft in I don't think you would be able to drive out in fwd.
Mike
I was wondering when someone would bring that up. But mud and hole are two very subject terms!Alot of times you are bouncing around in the mud, I don't think it would be that difficult to get air and land and get enough traction to break a axle shaft or worseIf a mud hole is bad enough to break a shaft in I don't think you would be able to drive out in fwd.
Mike
I know some guys here are running modded shafts and the such but every time I have seen someone do a front burn with stock shafts, they break something. So unless you have upgraded shafts I wouldn't say its much of an advantage.
