cegusman
3/4 ton status
One thing I did not see covered. Will this prevent you from running bump-stops in the stock locations? Looks like the passenger one will contact the axle mount.
I have no bump stops but it would interfere i plan on doing something about it but un sure as of yet.
Here is one on a K5 with the axle moved forward only about an inch, and it clears just fine! Of course, different vehicles and different axle locations may be hard to predict, but I haven't run across any yet that we haven't been able to fit together!
sent email the other day. no reply yet. site shows big shop move.
figures last setup i wanted he dosnt reply anymore life to bussy.
then this one nice and now no replys.
Anyone install this kit with the ORD High steer / Cross over set up?
Thanks,
Ed
It should be fine check my build i have crossover and it clears i have high steer arms just never moved the tie rod up. My drag link is in the rear ward hole so the tie rod would be in front of the drag link.
