1988 TBI 5.7 manual trans
I am beat up and sore. ended up spending most of the weekend swapping my old motor back into the blazer. something is wrong.
the few times I've been able to get it running -seems like a timing issue. scratching my head and could use some help. Its parked at my office and cant stay here - needs to move tonight or tomorrow.
the motor that I just put back in had low compression in one CYL, but was actually still running well when pulled. It had a broken piston ring. I replaces the rings on that piston and did a quick hone job on that CYL only. the cam never came out or moved... I put the head back on and adjusted the valves. pulled the knocking motor sat morning- put this "repaired" engine back in.
I spent all day yesterday trying to get it to run.
-its getting fuel. injectors are spraying.
i have had it running (horribly rough- backfiring - stumbling) and it sounds like a timing issue.
- i shocked myself trying to turn the distributor when my hand was swetty... was off one of the plug wire terminals- not the coil thankfully - its definitely sparking...
i twisted the distributor counter clockwise and was able to get it to idle, but it sounds RETARDED - last time I had an issue like this, the timing was retarded by 20-30 degrees, and the computer was trying hard to catch up, but ran out of adjusment. after fixing the base timing, I was able to get it running well - NOT THIS TIIME. Im twisting the distributor way farther than i think should be necesssary. it feels like im turning it so far that #1 terminal and plug wire are crossing over into #2s territory. The wiring on the coil and the length of the plug wires prevents me from twisting the distributor any further...
When I disconnect the ESC wire - you would normally be able to set timing to 0 degrees - the engine dies- its not capable of running when the computer isnt helping with timing. i cant even see the mark on the balancer when my timing light is going. ive set the motor to TDC about 10 times and pulled/ reinstalled the DIZZY and rewired the cap... checked/doublechecked the firing order.
I have tried another distributor (with what is probably an incorrect ICM) and not having much better luck.
