1BEATK5
I do believe you're right. I suspected it when I saw it was right under the mark, but it sure looked dry to me.
Now that you showed me, I clicked on the pic and enlarged it. I see the stain you are talking about. Its sure not much of a leak, but just enough to cause that stain.
If you enlarge the pic and look at the very bottom of the rear housing, there is a small shiny or white dot.
Missing bolt, or just an artifact?
if you crawled under the truck and looked at the back of that debris deflector i bet its wet. but the angle on it prevents fluid from coming forward of that point. not to mention the airflow under the truck would also prevent it from coming forward
