garydan
Ok, I just picked up a 1985 K5 blazer, the body is in great condition. The motor is 400ci with Hedman Headers, true dual exhaust. I don't know any other specs on the motor, but I can tell there is a decent cam in there. I have so many questions I don't know where to start. I'm used to working on an LS1 camaro. So the
idea of tuning a carb is quite foreign to me. So here we go:
I'm going through a basic inspections process. I'll be changing the oil, flushing the coolant, changing the rear-end oil, checking the brakes, changing the air & fuel filters.
There are many more questions to come, including questions about servicing the 4wd components and transmission, but I'll stop here for now
Thanks for your time and responses!
Edit: Oh... one more "stupid" question. How the hell do you jack one of these trucks up? It has 35 inch tires on it, and its lifted (not sure how much though). I have a good size jack, but I doubt it will go high enough to take a wheel off (unless I jack it from the pumpkin). What are the recommended jacking methods.
- Does this truck take Dex-Cool? What is the recommended coolant. What ratio of water to coolant should be used (50/50?) ?
- I popped the cap off the radiator and saw nice green coolant about 6-8 inches down. Is that an ok level? The external coolant reservoir was empty. I also noticed this rust colored film inside the radiator. Like I said the coolant I saw looked green, but the metal inside of the radiator I saw was brownish in color. Is that normal? If not what should I do about it.
- Spark Plugs. Should I go with platinum or is there a standard type of plug that works well with these motors (400ci sb)? What gap should I have?
- Is there a good Service manual available for the 1985 Blazer?
- What about rear-end oil. I'm know I'll need a gasket (or rtv sealant?) and gear oil. Any recommendations here? Do I need an additive like I did with the 12-bolt I had in the camaro?
- Fuel Filter. Any recommendations here? I'm not sure what I'm asking. I guess I'll just find the filter and take it to the auto-parts store and get a new similar model.
Thanks for your time and responses!Edit: Oh... one more "stupid" question. How the hell do you jack one of these trucks up? It has 35 inch tires on it, and its lifted (not sure how much though). I have a good size jack, but I doubt it will go high enough to take a wheel off (unless I jack it from the pumpkin). What are the recommended jacking methods.
