(k5 krawler 50): You have new springs, so if your truck is actually leaning to one side its from something else, but...
Axles have two torques acting on them because the differential changes the rotational torque 90 degrees.
Basically, torque is transmitted through the ring gear/axle shafts/etc. This creates an opposing torque which is resisted by the leaves (causing axle wrap).
At the same time, the pinion gear is transmitting torque to the ring gear and everything downhill of that. The pinion also creates an opposite torque which causes the passenger side of the suspension to squat (because the yokes rotate clockwise when you look at the front of the diff).
There aren't many reasonable options to counteract the torque of the pinion but there is a good side to this: its 3-4 times smaller than the axle wrap torque (the torque that the pinion creates is smaller than axle wrap torque by a factor of the axle's gear ratio).
I really wasn't helping your problem any, just pointing out that is one thing that can wear out springs on one side quicker than the other. My rear passenger spring is significantly more bent than my driver side, largely due to this IMO.
As for axle wrap (the much more relevant resistant torque), antiwrap bars are designed exactly for this. If you add an antiwrap bar make sure to weld the axle tubes to the pumpkin (search for the correct way to weld this up).
I hope most of that makes sense
