Undercoat/ insulation
nah, not at all, ones oil based, the other water based.. just paint over it...
Yup. I brushed/sprayed that stuff on THICK in my burb... then some bedliner and paint over the top where needed with quite good results. I waited about 3wks (in the summer) to topcoat it (which I'm sure is overkill). The thick layer seemed to cure slowly.
I like it well. Several coats went on 2-3mm thick! Did the sides and floor of the burb in addition to rubberized undercoating the undercarriage. I slso used the butyl adhesive sound deadening mats on the doors/roof.
The interior noise reduced dramatically.
