ItsTwest
Registered Member
Rims i'm looking at have 3.70" backspacing with an offset of -19mm. How much does that add up to in inches for backspacing?
backspace is all you need to know...offset doesn't mean anything to a truck. if you need 4" from the back of the rim to the mating surface..... get 4" bs... offset just confuses people
I'd say just the opposite.
Backspace only affects wheel to TRE clearance.
Offset is what determines where the tire actually ends up.
When measuring how big tires I can fit and/or how much to cut the fenders, that's the only thing I look at.
if you know you have a 9" wide wheel.... and you have a 4" bs, then you have .5" offset. its simple math really. look at any 2 wheels with the same width and bs and they will have the same offset. its just 2 different ways of saying the same thing.
