Eisenkreuz
Registered Member
for my engine swap and cleaning the bay i could use some help identifying these parts. it's a 1981 blazer, 2wd, everything manual, no AC, no cruise control...
there's this thing behind the power brake booster
one green cable goes to the trans (is this for Backup-light?) on the other side is what i believe is a vacuum pump. but what use is that vac for?
http://db.tt/2o6Oauqo
and this cable string on the firewall above the trans (with a huuuge rubber gromet)
http://db.tt/freKYhzE
orange goes to distributor i think. the connector with the 4 pins has no equivalent. it's wires are brown, black, yellow, green. also seperate in that string is blue for either water temp or oil pressure
can someone help. didn't find these in a wiring chart.
