I have just about all my gauges finally. Still waiting on one. I can get started with out it. I'm getting ready to cut the holes for the dash and cant decide which look and layout looks good and which works the best for what I want to have in the dash. I still need to but the HOT ROD AIR unit. The controls I would like pretty much on center of the dash. I also thought about having one of the those trick Computers with GPS like a trophy truck uses. Have not looked into one of those yet. Probably can't afford one anyways.
Anyways I would like to pick your brains, maybe I'm forgetting something. I layed these out with the dash in the truck and the new colume & steering wheel installed. I kinda like having a gauge on the upper left but it will be closer to the tach/speedo just due to space available. The gauges on the right are spaced farther to the right because it gives me better view above the steering wheel. I still would be able to see the gauge on the left fine, it's just closer to the wheel then I would like. Was thing of the fuel gauge on the left since it's not a engine critical gauge.
OR, I could just have them all in a row on the right and nothing on the left. It just seems empty on the left. I will also have a switch pannel somewhere aswell. I would like the passenger to have access to it too. Same with the AC/heater controls. I can add a lower Aluminum pannel IF necessary, IF I just do not have the room for everything necessary, But, I would prefer NOT to add anything. I like the straight across clean dash.
I'm going to maching custom gauge clamps to mount the gauges to the dash on the back. The angled bezels create an issue as far as mounting goes. I have that already figured out. Well what do you think? see any issues with the gauges being close together or any other problems? I really have to watch how close to the top I mount them. The dash bar runs behind the dash. Also the Dzus fasteners still need to be welded to the cage and the holes drilled in the dash so I can mount it solidly to the cage.
Refference links to my build
http://coloradok5.com/forums/showthread.php?t=235879
http://coloradok5.com/forums/showthread.php?t=229674
http://coloradok5.com/forums/showthread.php?t=237109&highlight=roll+aluminum
I have waited almost a year and a half for these to come out.
