Title says it all... What is the best bang for your buck upgrade for a TBI 350?
Any power mods you do to a TBI motor is pretty low bang for the buck.
And really, ask yourself, why do you want more power? What do you want the truck to do?
Propane...![]()
He never said anything about more power. There are mods you can do that will help with how well it runs and as an added bonus just happens to increase a little power at the same time.
Propane requires a higher compression ratio, uses more, and makes LESS power than gas, the only advantage I see with propane is that it burns clean.
Propane on a TBI truck aint going to give you any bang. Cost you a lotta bucks tho......Have you ever ran propane???
It's actually very cheap to build these trucks... I'm into my Blazer for $2800, that includes buying it...
also long tubes are much more prone to starter heat soak and tight shackle/collector interference...
