well i finally got the 52's straightened out. asa few suggested im running the rear hangers in the stock location. the angle isnt the best, but for now it will work. i also swapped in another d60 with 4.56's and put my new steering on. i also redrilled the d60 perches 1" so that my axle will be 3.5" forward, which looks like its perfect for the tie-rod to clear the 6.2 oil pan. however check out my spring plates. the driverside has no clearance with the tie-rod, while the pass side has plenty. on the pass side im running a shim to fix the angle, i think if i do the same on the driverside it will solve the current clearance issue, thats the only difference between the two sides.
what yall think?
what yall think?
Looks great!
the reason im having the clearance issue with the spring plates is becuase i drilled the perces back 1" so the tierod is closer to the spring plates
