Re: When coasting at high speeds, doubler makes bad gear noises, please hel
If you have an angle finder put it on the shaft and get the angle reading of it. The remove the shaft from the pinion end and get a reading of the pinion angle. These two angles should be about the same. The pinion wants to be slightly lower then straight with the shaft. The picture of the driveshaft and pinion angle posted above is about as perfect as you can get, for a CV shaft application. Make yours look like that.
If you need more than a few degrees call ORD and get a set of their shims that bolt onto the spring pack. I think they make them in 2,4,6 degrees.
After you get this all corrected change the u joint at the pinion end of the shaft. I fought a drivline vibration for a long time and it always helped when I changed that u joint.
