juanblzer
The method to the madness:
I want a truck that looks like a truck. I also want a truck that I can beat the crap out of and not care too much about. I also want to have as little sheet metal as possible.
The solution. Removable bodypanels utilizing dzus fasteners and Autofab hoodpins. Also removable: the substructure that holds on the fiberglass panels.
This facilitates crawling without the worry of body panels... and way less negative attention from la policia
How it will kind of look... This is a 2wd race truck with the same fiberglass I will have on my truck. Check out those a-arms!
Trailer products race fiberglass mocked up on my blazer...
Without body panels (with sheetmetal hood)
still to come:
Soon...inner panels (using sheet ABS plastic instead of aluminum) to keep debris from coming in to the passenger area or waterbottles coming out.
In May...triple bypass King shocks with revalving for the coilovers at the same time
winch
bfg 39 inch Baja projects off of a race truck for a street set of tires
rear disk brakes
emergency brake
yesterday on the before and after getting it on the trailer.
Finally mounted... and on the driveway ready for final trimming...
still to come:
winch
rear disk brakes
emergency brake
