{updated}lots of 10 bolt parts: 1350 Yoke Front Shafts Carrier Blocks Traction Bars
K5Chris
Texas
DETROIT locker for 10 bolt: SOLD
SPICER 1350 yoke (u-bolt style) for 10 bolt w/ new u-bolt set: $45
30 spline open carrier: $35
30 spline front axle shaft set: $35
30 spline front axle shaft set w/ new Spicer ujoints: SOLD
5.5” Tuff Country tapered cast iron lift blocks w/ u-bolts for 3/4 - 1 ton axle: $35
Traction bar setup for 73-87(91). Adjustable, goes above leaf springs, (works with half ton axle with stock springs or stock springs & blocks): $35
Spicer 1310 style 10 bolt yokes (2): $5/ea
Saginaw S44 style 10 bolt yoke: SOLD
10 bolt diff covers, 2 rears/1 front: $5/ea
Carrier bearing caps w/ bolts: $5/ea set
front 10 bolt u-bolt set: $5
23 piece chrome lug nut set (one missing) for steel wheels, includes 5 piece lock & key set: $5
will trade for Dana 60 parts, crossover steering parts, 1 ton front driveshaft, tube bumpers, rock sliders, winch, interior trim parts, or 37-42" tires.
k5chris at ymail.com
shipping from Lafayette, Louisiana
are they homemade and how exactly do they mount to?
They are not homemade. I tried to find installed pictures, but I lost alot of my old pictures in a hard drive failure.
You drill 3 holes in the back side of your front spring hanger, and mount the square bracket to it. The stud end of the bar goes into the bushing in that bracket. The other bracket bolts to the top of your spring plate using 2 of your existing axle u-bolts (the spacing of the holes for the ubolts would require a 1/2 ton axle) The other end of the bar bolts to one of the 3 holes of that bracket. You could fabricate a new rear bracket with holes that would line up with 1-ton u-bolts. They were on my truck when I had factory 52's in the rear with a 3" block, and seemed to work well.
I found them... they sell for $160. http://www.jcwhitney.com/TUFF-COUNT...0220_N_111+1985+200729944+600003505_10101.jcw
