Sold UPDATED ORD, DIY, WFO, PSC suspension and steering parts.
BTracy
Registered Member
Updated to remove parts that have sold and dropped the prices.
My K5 is headed further into truggy territory, and I have decided to not hoard the takeoff parts. Some of these parts are still on the truck but will be removed soon. I'll get picture's later today.
PSC steering box with a 3.5-inch drop pitman arm and steering ram from ORD's spec built hydro assist kit. Pretty sure this kit was installed in 2019, worked awesome turning 38's on 1 tons. I am keeping the pump and reservoir. 750$
ORD drop drag link with drag link ends. Ends feel tight, boots are not torn but I would replace them with the new Kevlar boots. 150$
Tie rod clamp for 1.5-inch tie rod. 75$
ORD Stock Length front leaf springs. Built for 5 inches of lift with a SB chevy and tube style front bumper. Leaf spring pin is 1 Inch forward of stock. Springs use the same size bushings front and rear. Springs have 6 degree shims on them, I think I have a few other sets I will include. 450$
WFO dana 60 leaf spring plates with u bolts. I used the studs on the 4-link install. The Passenger plate was slotted to work with offset leaf spring pins. 75$
Parts are in Dacono CO, I will work to ship them on buyers dime. Commercial account through work gets a little better rates.
I'll take fush kit.
I ordered the fitting needed to run AN fitting all through the steering. There are no O ring or flare fittings in the steering lines.
Picture is the 60 cover. I machined the tie rod clamp.
Only photo of the spring plates I have right now. I can take another tonight if you want.
I want it, can you get me a shipping quote to a business in 38668 Senatobia, MS.
Is the ram is available? Pics? I'll probably take it
What’s the chance you still have the hydro assist setup?
