Updating older 3 row 28x17 core radiator
77ck5
Arizona, CA
I'm needing to update to an aluminum radiator for when i get the new engine eventually. It currently has an old 3 row brass radiator with a 28x17" core in it. Can I swap in a 28x19 core sized radiator without a whole lot of issues? Hoping just some new brackets for the top along with a new cover for the top of the radiator? Would the current shroud work with this size radiator ? Trying to get a bit more cooling area and keep the mechanical fan setup if possible. Also would you recommend updating the fanclutch at the same time since I am in there as old one looking pretty crusty ? I have been looking at the HD models and have seen a severe model as well?
If you can make the top work the shroud should work as long as it's attached at the top somehow with the new setup on top.
2" is a lot to compensate for so you may have your work cut out for you.
Can you post a picture of your setup now with the original radiator and without the top plate?
Did you consider going with big block radiator size?
I have the top plate for your truck year
I was trying to stay close to stock perimeter so I did not have to hunt down a bunch of stuff. What size is the bbc radiator anyhow? Was that a surburban motor
The BBC radiator is bigger than the SBC one and the diesel one is even bigger. The core supports are all the same and have extra holes for attaching the various size radiators. You do need the brackets and stuff to match when you change the size. There was a thread recently discussing which brands are junk (most) and who still offers a good one.
454 was optional in many models like K20, K30, K20 Suburban, etc, but never in a K5. Regardless, all of these trucks got the same core support (although they do vary by model year to account for grill/headlight differences).
If you get the one for a 454 in a k20 I have the original top cover for your year
Is there anything wrong with the current radiator? The quality on aluminum radiators is hit or miss, while the "old" stuff works just fine or better.
No idea how old current radiator is but the truck had sat for so many years but at least 15 or 20 yrs. It was half full of fluid and tons of crud at the end of the 3 rows when I first opened it up to check. I would hate to hook it up to a new motor and have that stuff flowing thru it.
It used to be a common service to get a radiator cleaned out. I don't know if radiator shops exist anymore, but you could possibly do it yourself with some solent or whatever.
If that is the concern start by cleaning it.
There are a few things that you can do without opening up and rodding it.
He is prepping for a new create engine. Should never put a new engine on an unserviced/old rad.
Also is going to have aluminum parts in new engine.
A new aluminum rad makes sense.
Fyi don't use dexcool or dexcool clonesin a brass rad. It attacks the solder
