Vacum modulator
mudjunkie 82
1 ton status
Cleveland Ohio
Vacuum modulator
not much into Transmissions so I have to ask but what does the Vacuum Modulator do on a Transmission???????
Modifies the transmissions shift points in relation to manifold vaccum. Also controlls fluid pressure.
low vaccume= (hard acceleration) it will hold the trans in a lower gear longer or downshift. For better performance.
high vaccume= Allows normal upshifting
Wnen they go bad or get a hole in them they hold the trans in first and wont let it shift to second.
