YoungMoneyVII
okay so I played a bit yesterday. Removed the cruise control servo and vacuum resevoir. Fixed the vacuum leak. Let me tell you. What a PITA to remove the servo. Had to bust out the 3 foot extension and swivel 14 like I was doing bellhousing bolts becasue the bracket for the servo is mounted to the driver head. So much cleaner look though. My heat still doesnt work im going to throw a blower motor at it and call it a day. I found the plug for my "4x4" light, just want to put it on the lift and blow air into it to get any grime out before I connect. Should my transaxle vent be all the way up near my shift linkage?
