van rear end question
69K5
Monroe, LA
would any van rearend be wider than a stock 14bolt. I found a d60 in a one ton dodge van. I dont mind grinding or welding for the perch and shock mounts. If its not the extra 3" of width I will just get the 14ff. its the same price either way. there are tons of 1ton dodge and ford vans around but I can never find a 1 ton chevy.
thanks
69k5
Unless it is a 35 spline rear 60 I would get the 14FF. If you want it the same width and cant wait until you find one from a van then run spacers.
Just my .02
Ira
I've been looking for a van for 2 years noe with no luck. I'll probably just run the spacers.
thanks
69k5
