I was doing some tinkering on the Jimmy and trying to think through my vapor lock problem and when it started. It could have started when I had all the soft lines replaced at the tank last time it was smogged. Return line for mechanical fuel pump is clear, checked with what was left from air compressor. So that isn't kinked. But maybe the one from vapor canister is. Or maybe canister itself is plugged. I will check the return line from canister tomorrow. 70$ to replace canister but I wonder, does it really help? Is it worth having? I know some carbs don't even have provisions for one. So could I just delete canister and plug off that port on carb? Then when I install new fuel filter with return, just use original fuel pump return line? Holley fuel pump has a built in regulator so just has a gozinta and a gozouta. Thanks in advance.
Joel
Joel
