I never had problems with my 74K5 back all the way to the later 80’s until this garbage ethanol fuel showed up did the issues show up with carbs.
Assuming you have ruled out the ignition failing at temps. Coils can fail when hot then work after they cool a bit.
I’m not sold on wrapping metal fuel lines but that’s just me.
You can remove the vent valve from the gas cap rather than drilling a hole.
Your symptoms are similar to what I’ve had. Go to Sonic’ on a hot day. Sit there for 15- 20 minutes or so. Hard to restart then then stumbles after short distance. Was always worse under heavy throttle. Doesn’t have to be super hot out either but the hotter the worse.
Ditto on the fuel pressure gauge if you like and/or a see through fuel filter temporarily up near the carb. I did both. You will see the gauge drop off and the fuel in the filter go down on a hot day sitting in the driveway after driving to full Temp and heat saturation.
Putting a water hose on the fuel pump and you will see the filter fill back up and the pressure come back after a few minutes.
Heat related will show itself.
I went as far as to install an electric fuel pressure gauge on top of the dash in the cab and low and behold whenever I had issues the fuel pressure dropped to zero in real time.
How many lines on the fuel pump, 2 or 3 ?
More on that later.
Get yourself a WIX 33041. Probably have to order it. You can use your evap vent line from the tank to canister as a return for testing
Fuel return to the tank is where I’m going with this. That’s why I ask about the fuel pump lines.
That’s all for now.
