Verify my pinion angle
broc944
Northern Minnesota
I am seeing if my pinion angle calculation is correct, I am going by this link
http://www.pirate4x4.com/tech/billavista/PR-shaft/index2.html
This is what I have, both set of slopes are in the same direction. Transfer case 3.5 degrees, drive shaft 9 degrees, and pinion is 16 degrees. so going by this statement
"If both slopes are in the same direction (up or down), subtract the lesser number from the greater to obtain the operating angle"
This gives me 5.5 degrees front and 7 degrees rear. I took my readings off of the yokes as per the article. Am I correct with my assumption that I am at 1.5 degrees total?
Are you sure both slopes are in the same direction.Also what type of drivline do you fhave now. Too be in the same angle the drivline would be slanting down , and the pinion would be slanted up past the transfer case angle. I just got done putting a new cv in my jimmy and for some reason your 1.5 does not sound right.
Mine is just like this, with the exception my numbers are what I posted in the first post.
I thought I was doing something wrong in figuring it out, but according to the article I am doing it correctly, I may be wording my findings incorrectly though:D .
Spicer recommends no more than a 3 Degree angle between pinion and shaft. This means that your front is off by 2.5 Degrees (not really very much), and the rear is off by 4 Degrees. My guess is that if you put a 4 Degree shim in the rear, and dropped the transfer case 2", this would put your drive shaft in the ball park of where it needs to be, but this is just a guess.
Here is what mine looks like (Dont laugh at my drawing capabilities) I do not have a CV just the stock slipyoke single joint:doah: .
If my math is wrong let me know I am worried about binding the top joint if I droop too much I have the stock s44 joint in the top and a conversion s44-1350 in the pinion.
Ira
The more I read the article on all of this, the more I get confused, what I want out of all this is the knowledge on how to figure this out correctly. I have had so many different people tell me so many different things, I frankly do not know what is correct and what is not. Then the article goes on to explain the pinion angle changing under cruise throttle, which also has to be compensated for. During the next year there are going to be many changes in my drive line angles, I figure I will have an assortment of shims to correct the angles, and I just want to make sure I am calculating the angles out correctly.
wouldnt you just want to get the t case and pinion on the same plane?:confused: meaning if your t case is pointing 3.5* down wouldnt you want the rear axle 3.5* up?
