NO NO NO!!!!
NOT OHMS!!!
Scott misstyped.
Use AMPS, not OHMS.
Ohms will blow the meter.
See what happens when i'm tired. Thanks for correcting me Fordum.
NO NO NO!!!!
NOT OHMS!!!
Scott misstyped.
Use AMPS, not OHMS.
ok after reading this i can tell you guys know what your talking about. now i just bought a 84 k5 and after the first alt went out on me and a battery i have found out that my alt wont turn on to charge my bat im not real good with wiring but the ground is good and so is my alt so please help me out.![]()
See what happens when i'm tired. Thanks for correcting me Fordum.![]()
And relays have 4 to 5 connections. One for signal, 1 ground, 1 12vt constant fused, 1/2 power out to .... So technically, wouldnt the relay automatically click as soon as power is applied through the system, as it is supplied all the time with a constant 12vt source?
Well, I burned up the meter, but it draws enough to kill the battery in 3 days. I have it narrowed down to the lights. On the ALT, there is a 14 gauge wire that is hooked up to the charging lug. It powers all the lights, wipers and memory circuit on the radio. Well its not the wipers, or the radio as I have pulled them fuses and no change. So Im goin back out and checking the back side of the fuse box for a problem, and narrowing it down. Its not the ALT itself either, just had it tested, tests perfect.
The relays should only click when something tries to turn them on. So the headlight relays should only click when you turn on the headlights (with the headlight switch off they should do nothing as you connect/disconnect the battery). They should only be warm when the headlights are on. This is the normal power dissipated by the coil resistance. If the relay is warm, it's "on". You may have wired them up backwards, swapping the NO/NC contacts (although some automotive relays don't have NC contacts). This implies that the fixed side of the coil should also be swapped from 12V to GND.One thing that might be getting me is the headlight wiring. The headlight switch is constantly powered, and it might be letting a little power leak past the switch and trying to turn the relays on. They seem like they are pretty warm to the touch even though they are never on except when I turn the headlights on.
