Vortec Heads on a sb400
I think building one would be a great learning experience for me as I've never done anything to the internals of a motor myself before. And, it'd be a great project to do with my son who is only 8 but.....
Oh, I was looking at new not rebuilt heads. I saw somewhere someone was talking about cast iron vortec heads? What's that about?
Yeah the production heads were iron
They are available new
for the price of a rebuild you can get a made to order crate motor. with a warranty if that's important to you. I bought a GM L31 Vortec 5.7l truck motor in 05 for $1500. Cost $2000 with shipping, not much more today. Throw in a good torquey cam and wear it out.
l31
I just snagged a barely run 383 Vortec last night. Drove 10 hours in the snowstorm to pay $800 for the whole engine.
It is a 5.7 Vortec roller cam engine with a new Scat 400 crank in it. Should be strong.
A 383 is a 350 w/ a 400 crank so it is almost the same as a 400 performance wise
Yeah I was thinking about that 400 crank in the 400 I have. But what is the benefits of a stroker? What about longevity? I've always had the thought with engines that a flame that burns so brightly can only burn for so long.
The biggest benefits are that it is easier to get a roller cam installed and they aren't as prone to cracking. I don't think I'd intentionally mangle a 400 to build a 383, just keep the 400 since you already have it.
The worst part of a 400 block is the bore size absolutely maxxed out the design and the Siamesed bores are weaker than in a 350 block
Way too big for a truck
depends on the valve size...
Considering a 400, with 2.02 valves it would be fine
biggest concern on a 3.75" stroke is the rod angle. This is why I did go with a 383. None of the crate engines have a 6" rod
I disagree. 225cc is way too big for a truck. That is an 8000 rpm head
I have 210s on a 350. Runs pretty good in a 6000 pound truck
Don’t get upset just cuz someone doesn’t agree with you. Participate in the conversation and we can all learn something
If you already got the 400, run the 400. Don't be swayed by the 383 non-sense
That said
I wouldn’t go 225 on the street on a 350.
Built 400, yes
That all depends on what your doing with the truck.
I have a set of heads that are flowing 335 on a 400 going in my truck.
Here's the dyno sheet
image (2).jpg she's making 486 ft lbs at 3600.
Should be fine in a truck
Here the dyno sheet
View attachment 291390 she's making 486 ft lbs at 3600.
I was going to ask you about the rod length on that one
Since were at it, What did those cc?
Got yo use a 5.7 rod on a 400 if you want to do it right.
In my opinion. Also ditch the externally balanced crank.
64cc head
How is a rod angle different in a 383 over a 400?? They have the same stroke, only thing is different is bore size, which means squat for stroke. I'd rather build the 400 than a 383. More torque, more power. I had many 400s, and never had any issues with them. Put 350 or the longer 6" and run it. If I had the money I'd build a 406 for my Yukon, should work good with the whipple….
Whats the difference if internal or external balance? Long as it's balanced. Costs more money to make a 400 crank internal or even to buy one over new flexplate and balancer.
