ericcarney
After a series of unfortunate circumstances, I ended up overheating my TBI sbc in my '88 K5 and cracked the block. I thought it was just the head gasket, tore it down replaced them and put it back together and still blowing coolant out. So I yanked a 5.7L vortec out of a wrecked '96 Tahoe and bought the intake manifold and adapter plate so I could keep my TBI. My buddy suggested I should just keep the serpentine belt system but I have heard something about problems with the water pump set up. 1. Can it be done? I have also noticed some extra hoses that aren't on my original water pump. The plug for the alternator is also different, the vortec alternator has four prongs and my original has two. 2. Can I just rewire the plug from the vortec harness? There is also no spot for the EGR on the intake manifold but I kept the exhaust manifolds from the vortec because I read somewhere that I can use the EGR tube on them. 3. What does it take to bypass the EGR? 4. If I just cap it off and go with no EGR, will it make the motor run different? 5. What other problems will I run into while making this swap? I am sure this is old news but there was nothing specific enough to address my particular problem when I was searching for the last three hours, haha. Any advice would be awesome, thanks.
agreed....
