^Yeah, that^ So I got everything in, Got the timing close, cranked it up and it sounded good. It sputters for about 5 sec when it is first cranked up and then smooths out like clockwork, revs up pretty smooth and sounds good. Went to drive it around the block and immediately noticed there was no power, got under the hood and adjusted the timing with a light to exactly tdc, still no power, my mechanic friend says no problem, timing needs to be 10-15 degrees advanced, make the adjustments, still no power and it gets worse the further I drive. I barely got it back up the driveway after taking it around the block, and the check engine light stays on the as soon as it cranks up. I was expecting that with the fact that the egr and the O2 sensor are gone now, but is that the reason why it is running so foul?
